Upgrading firmware on a WLC
Feb 3rd, 2009
I would like to consider upgrading the firmware on my 4400 WLC from version 4 to version 5, but wondering what the steps would involve on doing this. Is it a major project to do, or is it fairly simple? I've been having issues with my AP's finding the wrong controller and read that the new firmware version has a better GUI and easier to fix this problem. I can open a case up with TAC on how to do this if it's too intensive to do over these forums. Thanks.
-Ryan
Scott Fella Tue, 02/03/2009 - 15:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I would not consider going to 5.x.... just my opinion though. 4.2.130 is stable and 4.2.176 fixes issues if you have 1252's. The 5.x in which has an option for high availability is to allow ap's a higher priority than others when you have a wlc failure and you don't have enough wlc to handle all the access points. If you plan on going with 5.x, stay away from 5.0. Upgrading will take time but is simple once you get a process down.
Leo Laohoo Tue, 02/03/2009 - 15:31
  • Hall of Fame,
    2017 LAN, Wireless
fella5 is right.
You are faced with two options:
1. Upgrade the firmware and the boot firmware (before you do, please refer to the Guidelines for Upgrading Controller Software: http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52mfw.html#wp1046424); or
2. Use the CLI (config ap primary-base ) on the WLC to force each AP to associate to the primary/secondary/tertiary controllers
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
