UC520 Call Quality
Feb 3rd, 2009
We have a UC520 with 4 FXO ports and have just started using the system. The LAN call quality is good but external call are very tinny and one caller said they thought we were "at the bottom of a well"
I saw one post suggesting we change from u-law to a-law but another saying that didnt apply for FXO
Can anyone please advise on what needs to be fine tuned (PS - previous analogue PBX call quality was very good)
Here is the Voice Port 0/1/0
Foreign Exchange Office 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is Configured by CCA 4 FXO-0/1/0-Custom
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar opx
Connection Number is 305
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for GB
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to complex2 Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard ETSI
DSP is pre-allocated
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal with Answer Supervision is enabled
Number Of Rings is set to 1
Supervisory Disconnect is dualtone pre-connect
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Thanks in advance
Paul
Nicholas Matthews Tue, 02/03/2009 - 17:47
Hi Paul,
Nothing particularly exciting on the voice port configuration here. You may try taking the DSP preallocate off and see if that makes a difference. It's hard to tell what configuration you have on the voice port from this command. You can start by taking all changes off the voice port and see if that helps.
Other things you can try:
-Different telephone wire
-Different port on the UC520
-"test voice port 0/1/0 thl-sweep" for the optimal impedance value
-'show proc cpu hist' make sure your CPU is fine
-'show call active voice brief | i lost' during the call for lost packets
-Confirm your latency is less than 150 ms (on a UC520 I highly doubt it is more than 150)
-Replace UC520 with analog phone, see if problem persists
hth,
nick
mparra.fusionet Tue, 02/03/2009 - 22:41
Hello Paul,
Yep changing the compand type from ulaw to alaw would only help if this was a BRI line out of the US.
Could you please attach a "sh run" just to have a quick look, we could try enable the
echo canceler, but I would like to see first what we have configured under the voice ports.
- Manny
warpsystems Wed, 02/04/2009 - 03:58
I ran the impedance test and it recommended Complex6, so we have changed to that - bt no discernable improvement.
Have also tried different port / cables, without joy
Have attached the file, hope its the correct details
Paul
