Force disconnect of WebVPN user?
Answered Question
Feb 3rd, 2009
Hello all,
I have WebVPN running on 8.04 and wonder if it is possible to force the disconnect of a user. I cannot find the command to do so? I ask because a user could not connect to the webvpn succesfully and the command "show vpnsession-db webvpn" command shows he is connected multiple times.
Any help is appreciated.
Matt
Correct Answer by JORGE RODRIGUEZ about 8 years 2 weeks ago
you may issue
to show user
show vpn-sessiondb webvpn | inc
to disconnect the user
vpn-sessiondb logoff name
if you are you allowing multiple sessions per user with a single logoff command will disconnect all user SSL sessions.
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 02/03/2009 - 19:42
you may issue
to show user
MATTHEW BECK Wed, 02/04/2009 - 06:17
Thanks! I don't know why I couldn't find that in the doc and just flat out missed it when doing ? ? ? after every conceivable VPN command.
Much appreciated.
Matt
