SRST Issue - Cannot make outbound calls
Feb 3rd, 2009
I am having issues getting SRST to function properly on 2811 configured as H323 gateway. When SRST mode takes over only 4 digits are allowed to be entered and cannot make outgoing calls on POTS lines. Gateway will not except more than 3 digits after 8 (used for secondary dialtone). Below are my dial-peers. Alias are working correctly on incoming calls during SRST. SRST is also configured correctly on CM and phones register as associated to correct SRST profile and device pool.
dial-peer voice 201 pots
preference 1
destination-pattern 911
no digit-strip
port 0/2/0
dial-peer voice 202 pots
preference 2
no digit-strip
port 0/2/1
dial-peer voice 203 pots
preference 3
no digit-strip
port 0/2/2
dial-peer voice 204 pots
preference 4
no digit-strip
port 0/2/3
dial-peer voice 205 pots
preference 1
destination-pattern 8911
port 0/2/0
forward-digits 3
dial-peer voice 206 pots
preference 2
port 0/2/1
forward-digits 3
dial-peer voice 207 pots
preference 3
port 0/2/2
forward-digits 3
dial-peer voice 208 pots
preference 4
port 0/2/3
forward-digits 3
dial-peer voice 209 pots
preference 1
destination-pattern 8T
port 0/2/0
dial-peer voice 210 pots
preference 2
port 0/2/1
dial-peer voice 211 pots
preference 3
port 0/2/2
dial-peer voice 212 pots
preference 4
port 0/2/3
call-manager-fallback
secondary-dialtone 8
max-conferences 16 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7960 2
ip source-address XXX.XXX.XXX.XXX port 2000
max-ephones 30
max-dn 144
system message primary SRST Mode - Contact IT
transfer-pattern .T
default-destination 2479
no huntstop
alias 1 2479 to 2460
alias 2 2479 to 2461 preference 1
alias 3 2479 to 2462 preference 2
alias 4 2479 to 2463 preference 3
alias 5 2479 to 2464 preference 4
date-format dd-mm-yy
Am I missing something? Thanks.
Overall Rating: 5 (1 ratings)
bwilloby46 Tue, 02/03/2009 - 20:18
I will definitely try that. Another question...Below are my voip dial peers. i recently changed the secondary dial out digit from 9 to 8 due to a ton of inadvertant 911 calls. Do i need to change my desitnation patterns on voip int's from [2-8]... to something else to reflect the change form 9 to 8 for outside line?
dial-peer voice 101 voip
preference 1
destination-pattern [2-8]...
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 102 voip
preference 2
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 103 voip
preference 3
voice-class codec 1
voice-class h323 1
no vad
bwilloby46 Tue, 02/03/2009 - 20:19
the pots dial-peers are listed below the voip dial peers as above.
bwilloby46 Tue, 02/03/2009 - 20:51
nevermind. found the issue plain as day.
shoud be [2-7]...
Thanks for your help, Nick
