WebVPN Tunnel-Group Aliases and URLS
Answered Question
Feb 3rd, 2009
<br />
<br />I have a requirement to create a new group policy and a new tunnel-group and apply it to a webvpn user account
<br />
<br />
<br />The web vpn is working fine without any issues when I give a new name under Group Aliases and URL
<br />
<br />My requirement is to use the existing Group Alias for this new tunnel-group. When I enter the existing alias it says it is already used by other tunnel-group
<br />
<br />Please help
Correct Answer by Farrukh Haroon about 7 years 11 months ago
If you use the same group-alias for two tunnel-groups, then how will the firewall distinguish between the two? Let say, as per your requirement you want to have the group-alias 'securevpn' for two tunnel-groups, TG1 and TG2. Now how will the firewall map a user landing on this alias to a group? TG1 or TG2? round-robin? :). This is not possible AFAIK.
Please rate if helpful.
Farrukh Haroon
CCIE # 20184 (Security)
Overall Rating: 4 (1 ratings)
Correct Answer
Farrukh Haroon Fri, 02/06/2009 - 22:04
Farrukh Haroon
csaravanan-sym Mon, 02/09/2009 - 14:53
Hi Farrukh,
Thanks for explaining me the concept. It helped me understand that you cannot have two tunnel-groups with the same alias
Chandru
