02-03-2009 10:39 PM - edited 03-06-2019 03:51 AM
I would like to stop BOOTP service on Cisco 3750 Switch running IOS Version 12.2(25)SEE4.Please share the commands.I am unable to run "no ip bootp server"
regards
Neo
02-03-2009 11:18 PM
I think u need to use the below command
no ip forward-protocol udp bootp
Mahmood
02-03-2009 11:28 PM
Thanks Mahmood for your response but if i stop BOOTP will my DHCP clients (windows Desktop) continue to get IP address from DHCP Server.
regards
Neo
02-03-2009 11:36 PM
Where u want this to be done is it on u r switch which is doing intervlan routing or someother switch.
If u are doing it on the switch which is doing intervlan routing i think u need to configure ip helper-address under u r SVI's.
Mahmood
