%ALIGN-3-SPURIOUS: & %ALIGN-3-TRACE: -Traceback=
Goutam Sanyal
Level 4
Level 4
Dear All,
For last few days I am getting the following log to my Cisco 1841 Router.
%ALIGN-3-SPURIOUS: Spurious memory access made at 0x61656290 reading 0x4
%ALIGN-3-TRACE: -Traceback= 0x61656290 0x61655528 0x614FA270 0x614FA254 0x0 0x0 0x0 0x0
%ALIGN-3-TRACE: -Traceback= 0x616562D4 0x61655528 0x614FA270 0x614FA254 0x0 0x0 0x0 0x0
As per Cisco:
%ALIGN-3-SPURIOUS: Spurious memory access made at [hex] reading [hex]
A spurious access occurs when a process attempts to read from the lowest region of memory. This portion of memory is reserved and should never be accessed. An attempted read operation to this region of memory is usually caused by the return of a nonexisting value to a function in the software.
Recommended Action: The system has detected the illegal access and was able to correct it without a system failure. This condition indicates a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train. If this message recurs, enter the show log, show alignment and show tech-support commands, contact your Cisco technical support representative, and provide the representative with the gathered information.
%ALIGN-3-TRACE: -Traceback= [hex] [hex] [hex] [hex] [hex] [hex] [hex] [hex]
This tracing message provides information about a previous ALIGN error.
Recommended Action: Copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
The same has been informed to Cisco and also the router has fully replaced. But after replacing the same is reflecting to router log.
Additional Details:
IOS : System image file is "flash:c1841-advsecurityk9-mz.124-3d.bin" and c1841-advsecurityk9-mz.124-1a.bin (with the both we are getting the same log)
Memory alignment:
1841#sh alignment
Alignment data for:
1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(3d), RELEASE SOFTWARE (fc3)
Compiled Tue 18-Apr-06 19:27 by alnguyen
No alignment data has been recorded.
Total Spurious Accesses 2, Recorded 2
Address Count Traceback
4 1 0x61656290 0x61655528 0x614FA270 0x614FA254
94 1 0x616562D4 0x61655528 0x614FA270 0x614FA254
SIL-CHATTISGARH-B'PUR-1841#
Any suggestion?
22 Replies 22
Giuseppe Larosa
Hello Goutam,
you should think of an IOS upgrade.
However, the sh alignment tells that there have been only two spurios accesses both recorded.
If this happens other times go for IOS upgrade.
Actually, we have some routers on branch offices complaining of something similar and they are still working.
if you don't notice any issue for users and traffic you can plan the upgrade quietly.
Hope to help
Giuseppe
Hello Giuseppe,
I am also thinking so. I have searched the same with "Cisco Bug Tool" and suggesting to upload c1841-advsecurityk9-mz.124-22.YB.bin. Lets see after upgrading the same.
Thanks for Help.
Goutam
I´ve the same problem:
Jul 27 22:37:42: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x41CDEBB0 reading 0x14
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CDEBB0 41CE2498 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CDEBB4 41CE2498 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CDEBC8 41CE2498 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 408F26A0 41CDEBF8 41CE2498 41FBB1D0 424B106C 42739324 42731E78 42B77CCC
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CDEBF8 41CE2498 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CE1718 41CE24BC 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CE171C 41CE24BC 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CE1730 41CE24BC 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 408F26A0 41CE1760 41CE24BC 41FBB1D0 424B106C 42739324 42731E78 42B77CCC
Jul 27 22:37:42: %ALIGN-3-TRACE: -Traceback= 41CE1760 41CE24BC 41FBB1D0 424B106C 42739324 42731E78 42B77CCC 00000000
CISCO-cat6509#sh alignment
Alignment data for:
s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXJ3, RELEASE SOFTWARE (fc1)
Compiled Mon 16-Apr-12 16:12 by prod_rel_team
Total Spurious Accesses 35, Recorded 10
      14      5  0x41CDEBB0 0x41CE2498 0x41FBB1D0 0x424B106C
                 0x42739324 0x42731E78 0x42B77CCC
      10      5  0x41CDEBB4 0x41CE2498 0x41FBB1D0 0x424B106C
       4      5  0x41CDEBC8 0x41CE2498 0x41FBB1D0 0x424B106C
      20      5  0x408F26A0 0x41CDEBF8 0x41CE2498 0x41FBB1D0
                 0x424B106C 0x42739324 0x42731E78 0x42B77CCC
       0      5  0x41CDEBF8 0x41CE2498 0x41FBB1D0 0x424B106C
      14      2  0x41CE1718 0x41CE24BC 0x41FBB1D0 0x424B106C
      10      2  0x41CE171C 0x41CE24BC 0x41FBB1D0 0x424B106C
       4      2  0x41CE1730 0x41CE24BC 0x41FBB1D0 0x424B106C
      20      2  0x408F26A0 0x41CE1760 0x41CE24BC 0x41FBB1D0
       0      2  0x41CE1760 0x41CE24BC 0x41FBB1D0 0x424B106C
Jackong
I am having the same problem too with my Cisco 2821
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M,
Nov 3 08:40:33.255: %ALIGN-3-CORRECT: Alignment correction made at 0x401B321Cz reading 0x3F003719
*Nov 3 08:40:33.255: %ALIGN-3-TRACE: -Traceback= 0x401B321Cz 0x402D6650z 0x402D68C8z 0x400726ECz 0x4019B9A4z 0xFFFF6620z 0xFFFF6620z 0xFFFF6620z
The advice is the same as in previous posts in this thread. An alignment error is a software issue. And a traceback is always an indication of a software issue. So you have two indications of software problems in the version of code that you are running. To fix the problem you need to change to a different version of software on your router.
Rick
Rick
Hi Rick,
But anyway the router is working with the configuration we set there will be any other issue if I will let this message appearing?
thanks for your response
Jason
Jason
You have indications of some sort of problem in the software version that you are running. But it appears that the impact of the problem is very small. In that case you can certainly just continue to run with the software that you currently have.
Rick
Rick
Hi Rick,
but it something weird for me about this router during the time of configuration and after saving the config, this messages is not appearing only when i connected it and put it on live environment
Jason
Jason
I believe that there is a simple explanation for what you observe. First let us remember something that was included in the original post "A spurious access occurs when a process attempts to read from the lowest region of memory." So the question becomes: when does this process execute? I suggest that whatever this process is that it does not execute during configuration and saving the config but does execute in response to something that happens when connected to the live environment.
Rick
Rick
Hi Rick,
ah okay.
btw can you take a look with the sh alignment result unlike from the first message from the thread for their router there is Spurious Access from their router but for me it is showing :
No spurious memory references have been recorded.
Instead:
please see at the attached file
Ok in some detail your issue is slightly different from the ones mentioned in previous posts. They report spurious memory access and you report alignment correction. I am not qualified to explain the differences between these messages. But you are reporting tracebacks as were the original posts. And a traceback is always a sign of a software problem. So your version of software is experiencing software failures of some sort. My advice does not change. If you want to solve the problem that you are experiencing you need to change the version of software that you are running. But if the software issue is very low impact then you may want to continue to run the version of software that you currently are running.
Rick
Rick
Hi Rick,
Thank you very much for your advise I've learned a lot from your thoughts and in technical view.
btw i'm planning to change the router hoping that the problem will solved but i'm worrying that it is in the same IOS version heheheh
Jason
Jason
Good luck with replacing the router. If you replace the router with one running exactly the same version then it is likely that you will continue to receive the tracebacks. But if the impact is low then it should be ok. Let us know how things are working after you replace the router.
Rick
Rick
Rick,
Hopefully we will not receive the same tracebacks.  But actually I haven't seen any big impact as of the moment because the router which is now receiving this message is still UP and this is the 4th day.
I hope Cisco is going to have some update tools to fix bugs like this in their IOS like windows update in Microsoft for fixing bugs instead of replacing its IOS version where like the device is in the remote places that the IT person needs to visit the area personally to change IOS version to fix bugs like this...heheheh
Actually we have the IOS version which is 12.4 which is working fine but the only problem we use this is because of the HWIC-2FE which is not detecting and we have to use it.
Jason
