Catalyst 6500 snmp linkup/linkdown trap not sent
theo.wiersma
Hi all,
<br />
<br />I configured my catalyst 6500 switch to send snmp V1 traps. The switch is sending all other traps, e.g. OSPF related traps, but it is not sending the Linkstatus traps (linkup/linkdown). Does anyone have a suggestion how to fix this problem?
<br />
<br />I included the relevant part of the config and the debug information
<br />
<br />Regards,
<br />
<br />Theo Wiersma
<br />
<br />
<br />
<br />1) Cat6500.log
<br />
9 Replies 9
Joe Clarke
The link isn't actual transitioning state. the linkDown trap tracks ifOperStatus, not ifAdminStatus. If you want an accurate test, you will need to shutdown an interface which is up.
I did the same test on a Catalyst 3560 and this platform was sending the trap messages. Tomorrow I will test it with a live port.
Thanks for the reply and I will let you know the results tomorrow!
I tested on a live interface and also added
SWBB0103(config)# snmp-server host 10.1.3.12 public chassis ospf hsrp bridge vtp vlancreate vlandelete envmon snmp config
so a trap is sent, when the config is changed, see the example below
SWBB0103#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SWBB0103(config)#
Feb 5 15:19:13: SNMP: Queuing packet to 10.1.3.12
Feb 5 15:19:13: SNMP: V1 Trap, ent ciscoConfigManMIB.2, addr 10.1.2.4, gentrap 6, spectrap 1
ccmHistoryEventEntry.3.409 = 1
ccmHistoryEventEntry.4.409 = 2
ccmHistoryEventEntry.5.409 = 3
Feb 5 15:19:14: SNMP: Packet sent via UDP to 10.1.3.12
SWBB0103(config)#int gi2/17
SWBB0103(config-if)#
SWBB0103(config-if)#shut
Feb 5 15:19:28: %LINK-5-CHANGED: Interface GigabitEthernet2/17, changed state to administratively down
Feb 5 15:19:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/17, changed state to down
SWBB0103(config-if)#no shut
Feb 5 15:19:35: %LINK-3-UPDOWN: Interface GigabitEthernet2/17, changed state to down
Feb 5 15:19:35: %LINK-SP-3-UPDOWN: Interface GigabitEthernet2/17, changed state to down
Feb 5 15:19:40: %LINK-3-UPDOWN: Interface GigabitEthernet2/17, changed state to up
Feb 5 15:19:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/17, changed state to up
Feb 5 15:19:40: %LINK-SP-3-UPDOWN: Interface GigabitEthernet2/17, changed state to up
Feb 5 15:19:40: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet2/17, changed state to up
SWBB0103#
SWBB0103#
SWBB0103#
Feb 5 15:19:52: %SYS-5-CONFIG_I: Configured from console by vty0 (10.1.15.165)
SWBB0103#
SWBB0103#u all
All possible debugging has been turned off
SWBB0103#
The Catalyst 6509 didn't a trap when the interface went up and down.
Any other hints or tips?
Theo
I can't reproduce this. Can you post the entire config from this switch?
Hi Joe,
I'd rather not publish the complete configuration of our live switch to the forum. Can I send it to you by a (private) E-mail?
Theo
If you can't post it hear, please open a TAC service request with this information.
Hi Joe,
Here's the config, I removed the passwords and other irrelevant settings.
I hope you are able to reproduce the problem!
Theo
I still cannot reproduce. The config looks okay, and I can't find any relevant bugs. You should probably open a TAC service request so more analysis can be done.
Hi Joe,
Thanks for the support.
I will open a TAC case to solve this issue.
Theo
