02-04-2009 02:27 AM
<br />
<br />I've got some questions about the LMS 2.6 (and maybe 3.1) customization.
<br />
<br />I'd like to generate Reports for the following:
<br />- Operational status of all interfaces (best would be with a counter for Up/Down/...)
<br />- (Average) CPU utilization
<br />- (average) memory utilization
<br />
<br />Is there any way to generate these reports in LMS 2.6 (or 3.1?)
<br />
<br />The only way i found while searching this forum was for the operational status to export all devices with "cwcli export inventory ... -device %" and parse the xml file.
<br />
<br />I would really prefer it, that im not forced to leave the CW Homepage for doing this. Is there any way to accomplish this?
<br />Or is it possible to customize the CW-homepage an add a link to a small Windows-Script? How should this look like?
<br />
<br />Thanks for all your input.
Solved! Go to Solution.
02-04-2009 09:12 AM
Yes, I had two bugs against RME custom reports where the attributes were very limited. All attributes are now available in RME 4.2.
02-04-2009 09:00 AM
CPU and memory utilization reports are available in the new Health and Utilization Monitor add-on to LMS 3.0.1 and higher.
As for interface status, you could define an RME custom inventory report under RME > Reports > Custom Reports Templates with a ruleset of:
Interface:Name:equals:All
AND:Interface:Admin Status:equals:All
AND:Interface:Operational Status:equals:All
When run against all devices managed by RME, this report will show you all the interfaces, and their admin and operational statuses.
02-04-2009 09:08 AM
Thank you for that fast answer.
Unfortunately i can only create a custom report in LMS 2.6 template with the attributes:
-Name
-Type
Will i have this possibility in LMS 3.1?
02-04-2009 09:12 AM
