LMS Authentication Failure
Answered Question
Feb 4th, 2009
This was working up until last week but now when I try to log into LMS I just get an authentication failure message.
LMS is configured to use ACS for access but ACS is not writing any information in the log files for the LMS server. So I can only assume that there is a problem with the link to ACS
How can I gain access to LMS and allow me to switch the system to a non-acs mode so I can access the server without first having logged in?
Correct Answer by Joe Clarke about 8 years 2 months ago
From the CLI, run the command:
NMSROOT/bin/perl NMSROOT/bin/ResetLoginModule.pl
You will then be able to login using local authentication and authorization.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 02/04/2009 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
