Fram relay Issue
Feb 4th, 2009
pvc Active but unable to ping POINT TO POINT network .The following configuration is as follows.please help
R1
interface Serial0/0/1
ip address 20.20.20.1 255.255.255.0
encapsulation frame-relay
clock rate 2000000
frame-relay lmi-type ansi
R2
interface Serial0
ip address 20.20.20.2 255.255.255.0
FR Switch
interface Serial0
no ip address
no fair-queue
frame-relay intf-type dce
frame-relay route 100 interface Serial1 101
interface Serial1
no ip address
clockrate 64000
frame-relay route 101 interface Serial0 100
Giuseppe Larosa Wed, 02/04/2009 - 04:38
  • Hall of Fame,
    Founding Member
Hello Manjunatha,
you are using the physical interfaces on R1 and R2.
add
R1
int ser0/0/1
frame-rel map ip 20.20.20.2 100 broadcast
R2
int ser0
frame-rel map ip 20.20.20.1 101 broadcast
or the opposite (the dlci parameter is the local one 100 or 101)
Hope to help
Giuseppe
Richard Burts Wed, 02/04/2009 - 04:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It appears that your configuration is depending on Inverse ARP to map IP address to PVC. Could you post the output of show frame-relay map so that we can verify if the correct mapping has been established?
Rick
ntmanjunath Thu, 02/05/2009 - 21:28
Router#sh frame-relay map
Serial0 (up): ip 20.20.20.1 dlci 100(0x64,0x1840), static,
broadcast,
CISCO, status deleted
Richard Burts Fri, 02/06/2009 - 12:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
This additional information is helpful. I believe that this:"status deleted" is an indication that the PVC is no longer active. Find why it is deleted instead of active and you will find how to get it to work.
Rick
1lumkk Fri, 02/06/2009 - 18:15
The status deleted indicates that the PVC has been erase from the service provider database. If the pvc is configure but not activated, it will appear as "Inactive". Hence, i would recommend to check with your provider for confirmation. Hope this give u a thinker. Rgds.
Edison Ortiz Fri, 02/06/2009 - 18:30
  • Hall of Fame,
    Founding Member
Let's identify what each router is learning from the frame-relay switch.
If you post the output from show frame pvc it will helps determine if you have the correct FR mappings.
It seems you are mapping 20.20.20.1 to an incorrect DLCI.
HTH,
__
Edison.
