IPS AIP-SM-10 Auto Upgrade Question
Feb 4th, 2009
Hi all,
I'm very new into the IPS configuration.
When i enable the auto update form cisco, do i still need to configure the sensor? Are the package files (.pkg) automatically applied to the sensor and capturing/blocking mailicious traffic ?
Overall Rating: 4 (1 ratings)
Farrukh Haroon Fri, 02/06/2009 - 21:55
The auto-update only pertains to the signature updates. You still need to configure the sensor as per your security policy. Also you might need to tune/disable those newly installed signatures as per the policy.
