port is not changing to auth vlan after bouncing NAC 4.1.3
Feb 4th, 2009
After the port taken into control under the profile & bounced it shoud change the vlan to the authentication vlan which is not happening. I have configured everythng as per best of my knoldge.
Can anyone pls guide me if anywhere I am missing something.
Thanks in advance
owillins Tue, 02/10/2009 - 13:13
The Access to Authentication VLAN Change Detection feature should only be used for OOB deployments that require client DHCP IP refresh/renew. If your OOB deployment makes use of port bouncing (Switch Management > Profiles > Port > New/Edit enabling the Bounce the port after VLAN is changed setting), this feature is not needed and should not be configured
