Newbie, really confused about clients
Feb 4th, 2009
Hi , I set and installed a ASA 5530 to replace our aging PIX. Now I am trying to use it to replace out old Nortel IPSEC based VPN concentrator. I want to use the Cisco IPSEC vpn client. When I install it I do not see anywhere to specify or use a username and password. Just a group name and password. What am I missing? I didn't want to purchase SSL licenses, just simply use the IPSEC client with local authentication to username and password. Thanks in advance for any help.
Steve
celiocarreto Wed, 02/04/2009 - 07:07
after successfull connect you will be asked for username and password.
If you don't get this window you have to check the Phase 1 and 2 parameters on the ASA.
this is a template for asa ans client VPN. Replace all $....
ip local pool USER $VPN_POOL_START-$VPN_POOL_END
access-list NO-NAT-INSIDE extended permit ip $INSIDE-IP $INSIDE-MASK $VPN_POOL_IP $VPN_POOL_NETMASK
access-list SPLIT-TUNNEL-USER extended permit ip $INSIDE-IP $INSIDE-MASK $VPN_POOL_IP $VPN_POOL_NETMASK
nat (inside) 0 access-list NO-NAT-INSIDE
crypto ipsec transform-set MYSET esp-3des esp-md5-hmac
crypto dynamic-map DYNMAP 10 set transform-set MYSET
crypto dynamic-map DYNMAP 10 set reverse-route
crypto map MYMAP 1000 ipsec-isakmp dynamic DYNMAP
crypto map MYMAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
group-policy USER internal
group-policy USER attributes
vpn-idle-timeout none
vpn-session-timeout none
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SPLIT-TUNNEL-USER
default-domain value $DOMAIN
tunnel-group USER type ipsec-ra
tunnel-group USER general-attributes
address-pool USER
default-group-policy USER
tunnel-group USER ipsec-attributes
pre-shared-key $GROUP_PASSWD
username $USER1 password $USER1_PASSWD
username $USER1 attributes
vpn-group-policy USER
group-lock value USER
Regards, Celio
srroeder Wed, 02/04/2009 - 07:56
Thank you Celio, I set up a group with key and I now have that part working. Can I ask you another question. I have some managers that would like to use, or try to test, the CSD, Cisco Secure Desktop, When I go into ASDM and check the option to turn on CSD it is then activated for all SSL connections. Is this by default? Can I create different groups or profiles so that some clients using AnyConnect can just connect and some users can get the CSD? Is this possible?
Steve
