Disconnect Cause=86
Answered Question
Feb 4th, 2009
I've a H.323 GW tryng to make a call through an FXO, and I receive 3 busy tones and then disconnect.
On debug I receive Disconnect Cause=86, but I haven't found the origin to this cause.
http://www.cisco.com/en/US/partner/docs/ios/12_3/vvf_c/voice_troubleshooting/old/vts_appa.html#wp1007724
On this link, this cause didn't appear.
Any idea about the origin?
TIA
Andres Pasten
Adexus S.A.
Correct Answer by Jaime Valencia about 8 years 2 months ago
that cause stands for:
Call having the requested call identity has been cleared.
if you connect an analog phone does a call work??
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 02/04/2009 - 06:58
  • Cisco Employee,
  • Hall of Fame,
    2011
java
andres.pasten Wed, 02/04/2009 - 07:19
The FXO is connected to a Huaweii IAD, so I move the FXO direct to PSTN to check the FXO and the call connected ok. The problem was on the IAD.
I was only interested in the disconnected cause. Do you have a link more complete than the one I send?
TIA
Andres Pasten
Adexus S.A.
Vikrant Ambhore Mon, 06/07/2010 - 21:56
Hi Andres Pasten,
I have Same issue regarding call disconnect also i'm getting Disconnect cause=86, i saw in forums you had same issue, can you suugest or help me for this issue, how to solved by you this issue, please i realy need your help
andres.pasten Tue, 06/08/2010 - 05:58
I´ve found a description for this issue:
86
Call Having the Requested Call Identity Has Been Cleared.
Indicates that the network has received a call resume request containing a call identity information
element indicating a suspended call that has in the meantime been cleared while suspended.
In my case the issue was on the IAD connected to my FXO, so the ISP changed the IAD for malfunction resolving the issue.
I suggest you to connect the FXO to something different (maybe another gw with a FXS) and check if the call pass ok.
See you.
Andres Pasten C.
Adexus S.A.
