Redirecting on CCM4.2
Feb 4th, 2009
Hi all,
do somebody know solution of this problem?
If you call from DN call identification is adjusted on RoutePattern by "Prefix Digits" parameter, which adds certain prefix. In this case everything works OK and your mobile shows perfectly calling number.
Problem is, when you redirect this DN, you call on it again, but even if the same route pattern is used, it doesnt add any prefix, which means that calling number is signalized just like short DN without prefix. On Gateway I got adjustment that it shows "first redirected number" which is correct I thing.
Do somebody have clue, why "RoutePattern" treats redirected and normal call diferently?
Thanks a lot.
aghaznavi Tue, 02/10/2009 - 08:10
It is not possible to prefix digits to Redirecting Number in CallManager, this works only for Calling Number. It could be possible in a gateway through voice translation rules but if you were using H323 instead MGCP, because translation rules apply over dial-peers and MGCP is not using this.
