Stand-alone MOH Server
Answered Question
Feb 4th, 2009
Currently we have our MOH server setup on CallManager 4.1(3)sr7 which supports about 100 end-users. Is there a need to setup a Windows 2003 Server for the MOH? We have been using a Fixed Audio Source, but are now creating .wav files (music w/advertising) to use. We have two remote offices.(possible load-sharing) Additional ideas on a stand-alone server would be much appreciated. Also, is there documentation for setting up a stand-alone MOH server?
Correct Answer by Jaime Valencia about 7 years 11 months ago
it's co-resident if ccm.exe is running along with IPVMS, if CCM.exe is NOT running but only IPVMS it's standalone
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 02/04/2009 - 08:16
a standalone MOH server is simply a CUCM server which is not running CCM.exe, only IPVMS services
java
bbtekgraf Wed, 02/04/2009 - 08:25
thank you for the reply. so since our cucm server is running ccm.exe and moh on the same server, moh is not stand-alone? or am i lost in translation?
Correct Answer
Jaime Valencia Wed, 02/04/2009 - 08:27
java
