02-04-2009 08:16 AM - edited 03-15-2019 03:59 PM
<br />
<br />I just get a brand new cisco 2801 and a VIC2-2FXS that I install in the slot 0 (VIC only).
<br />
<br />I can see my card in the sh diag and sh ver but the voice ports never appear on the sh run. I can't type voice-port either...
<br />
<br />Router#sh ver
<br />Cisco IOS Software, 2801 Software (C2801-IPVOICE-M), Version 12.3(11)YZ2, RELEASE SOFTWARE (fc2)
<br />Technical Support: http://www.cisco.com/techsupport
<br />Copyright (c) 1986-2007 by Cisco Systems, Inc.
<br />Compiled Wed 08-Aug-07 23:47 by dchih
<br />
<br />ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
<br />
<br />Router uptime is 21 minutes
<br />System returned to ROM by power-on
<br />System image file is "flash:c2801-ipvoice-mz.123-11.YZ2.bin"
<br />
<br />Cisco 2801 (revision 7.0) with 115712K/15360K bytes of memory.
<br />Processor board ID FCZ124611SS
<br />2 FastEthernet interfaces
<br />2 Voice FXS interfaces
<br />DRAM configuration is 64 bits wide with parity disabled.
<br />191K bytes of NVRAM.
<br />62720K bytes of ATA CompactFlash (Read/Write)
<br />
<br />Configuration register is 0x2102
<br />
Solved! Go to Solution.
02-04-2009 08:34 AM
You will need PVDM2 in all ISR routers to turn up the voice ports. If no dsp's exist then you will not have that ability to configure them.
02-04-2009 08:24 AM
You have no PVDM2-xx modules in the box. These are the DSP and no use of voice ports can be done without.
02-04-2009 08:26 AM
Would I get the same problem using a cisco 2811 ?
02-04-2009 08:34 AM
