Shared line with SCCP phone and a h323 client
Answered Question
Feb 4th, 2009
I have a Cisco 827-4v router that I want to integrate into UCM6. I also have a 7940 that I would like to have use the same directory number on it. Since the 827 only supports h323, how can I setup a shared line so both the 7940 and a FXS rings on the 827 so both phones ring?
Thanks!
Correct Answer by gogasca about 8 years 4 months ago
Not possible to do it so far since Device are different and we cannot internally extend the call to 2 devices....BUT thats when Mobile Connect comes into play.
You can configure your H323 as Remote Destination using Mobility Manager 1.X or CUCM 6.X.
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Wed, 02/04/2009 - 22:15
  • Green, 3000 points or more
