02-04-2009 10:45 AM - edited 03-06-2019 03:51 AM
I have a switch that connects to a 2800's f/e port. The switches port is configured to trunk only vlan 2. There is also an SVI on the switch for vlan 2. However, the router port only does layer 3 and the SVI needs to be routed across the WAN. How can I trunk vlan 2 from the switch to the router and keep the router's port layer3.
Here is the 2800's port:
interface FastEthernet0/1
ip vrf forwarding VRF10
ip address 10.33.10.17 255.255.255.240
ip helper-address 10.10.33.10
duplex auto
speed auto
vlan-id dot1q 2
exit-vlan-config
The last command I added, vlan-id dot1q 2 is a shot in the dark...not sure if that works...anybody know?
Here is the switch:
interface Vlan2
ip address 10.33.10.18 255.255.255.240
interface GigabitEthernet0/1
switchport trunk allowed vlan 2
switchport mode trunk
Solved! Go to Solution.
02-04-2009 11:10 AM
On the 2800's FE port you will need to create a sub interface on for vlan 2. Here is an example below.
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.30
description Data VLAN
encapsulation dot1Q 30
ip address 10.0.30.1 255.255.255.0
interface FastEthernet0/0.40
description Voice VLAN
encapsulation dot1Q 40
ip address 10.0.40.1 255.255.255.0
HTH,
Mark
02-04-2009 11:23 AM
Aaron
The suggestion by Mark is good if you need the connection from the switch to the router to be a trunk - especially if there are multiple VLANs to transport.
But your original post specifies that only a single VLAN is supposed to go over that link. In this case there are a couple of alternatives to consider:
- you would not need to configure the router interface with subinterfaces if you leave the switch port as a trunk and configure VLAN 2 as the native VLAN on the switch. Frames for the native VLAN are sent untagged (they are just normal Ethernet frames) which the router interface should recognize and be able to process.
- if only a single VLAN is transported I question why the switch port should be a trunk. To transport only VLAN 2 traffic you could just make the switch port an access port in VLAN 2. In this case the router interface would just be a standard FastEthernet interface configuration and there is no consideration of trunking.
Rick
02-04-2009 11:10 AM
no ip address
duplex auto
speed auto
HTH,
Mark
02-04-2009 11:23 AM
Aaron
Rick
02-04-2009 11:39 AM
Aaron
I am glad that our responses were helpful in resolving your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that there were responses which did lead to resolving the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
