Warning message
Idea switch temp?
Feb 4th, 2009
I am just curious what is the ideal temp for a cat 3560/6500 series switches?
<br />
<br />I have a situation where I have some equipment that is in a space where temp fluctuates. Is there a point where a network engineer picks up a phone and calls an AC guy?
<br />
<br />Obvioulsy I'm not talking about the extremes in temperature(i.e., 100 degrees in the room).
<br />
<br />much thanks
<br />e-
<br />
<br />
**ugh sorry, I just realized I put this in the wrong forum.
Edison Ortiz Wed, 02/04/2009 - 15:07
  • Hall of Fame,
    Founding Member
From the 3560 Data Sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
• Operating temperature: 32 to 113ºF (0 to 45ºC)
• Storage temperature: -13 to 158ºF (-25 to 70ºC)
• Operating relative humidity: 10 to 85% (noncondensing)
• Operating altitude: Up to 10,000 ft (3049m)
• Storage altitude: Up to 15,000 ft (4573m)
As long as you are within those values, you should be fine.
HTH,
__
Edison.
