Cisco 4400 summary page doesn't display proper # of active AP's
Feb 4th, 2009
4400 series WLC with 100 supported AP's.
present capacity is 62 active AP's but summary only shows 48 active...Why???????
Leo Laohoo Wed, 02/04/2009 - 12:53
Means that 14 of the AP's are not joining. You'll need to do a "floor walk" and find out which AP's LED are flashing. When you find them, console into the AP's (Username/Password: Cisco) and type in the following command:
lwapp ap controller ip address
Does this help?
Scott Pickles Tue, 04/28/2009 - 11:06
I'm sure this has been figured out by now, but just in case it hasn't, or the solution was unclear, you probably only have one of the controller's gigabit interfaces plugged in, or you don't have enough ap-managers configured. For more than 48 APs, you need more than one link connected. If you are using LAG, you should be all set with one ap-manager. If you are not using LAG, you need to connect at least two ports for 62 APs, and you will need a second ap-manager IP address configured.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
