Can we use BAT to update built in bridge
Feb 4th, 2009
CM 4.2. Does anybody know whether we can use BAT tool to update the built-in-bridge(the feature to provide barge on share line) on phone configuration? It seems bat template can configure this when add new phones, but update phone doesn't seem have this option. thanks
David Hailey Wed, 02/04/2009 - 20:10
There is an Enterprise Parameter to enable Built-In Bridge which is disabled by default. You can enable this setting and then phones use the "Default" as their setting by default - which will now be turned on via the system parameter.
