num-exp question
Feb 4th, 2009
I have the following testing config in Global config
num-exp 5... 1904555....
I enter the number 5651 and am expecting 1904555 to be prepended and get 19045555651 returned.
I checked it with "sh num-exp 5650" and get the following in return
sh num-exp 5651
No num-exp with Dest Digit Pattern = 5651
Ideas, opinions and assitance please
jbayuka Thu, 02/12/2009 - 06:42
  • Bronze, 100 points or more
If you are using SRST num-exp doesn't work in SRST is basically that the num-exp works in conjunction with the destination pattern. The dest-pattern needs to be in the same format as the num-exp for it to kick in. Since in SRST you will create dial-peers using the full extension (~destination pattern = SRST phone), you won't see the num-exp kicking in.
