Unity - Mailbox clash
Feb 4th, 2009
<br />I have Unity 7 which I want to integrate with 2 separate CUCM 4.1 clusters, the only problem I have is that their are duplicate extension numbers between the 2 sites, can this be done and if so how.
<br />All the users are in the same AD domain
this is for Unified messaging with Exchange
Jaime Valencia Wed, 02/04/2009 - 13:16
  • Cisco Employee,
  • Hall of Fame,
    2011
you'll need to configure the VM profile with a mask and add an extra digit for each site to do this. also configure the appropriate translation patterns for dialing from unity to CUCM and to allow MWI to work enable the multitenant parameter
java
if this helps, please rate
