The number of isolated vlan in private vlan
Answered Question
Feb 4th, 2009
  • Bronze, 100 points or more
Hi every body!
I was reading about isolated vlan in cisco book.That is what the cisco book says:
"Only one isolated VLAN can be mapped to a primary VLAN, but multiple community VLANs can be mapped to a primary VLAN."
My question is does it mean there could maximum one isolated vlan private vlan in a vlan? If there can be more than one, then how will the communication occur between two isolated private vlans in a vlan as one one isolated vlan is mapped to primary vlan?
thanks a lot and have a nice day!
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Jon,
thanks for your correction
let's give Sarah good information.
It is the opposite of what I have understood/remembered:
instead of having all isolated ports in many single isolated secondary vlans you can have multiple ports all belonging to the same isolated secondary vlan.
This allows for an implementation without wasting vlans numbers
Sarah: sorry for having given you a wrong information your questions are becoming difficult to answer :)
Giuseppe
Correct Answer by Jon Marshall about 8 years 5 months ago
Sarah
Firstly good luck with your exam.
Secondly all the docs i have read suggest that you can only have one isolated vlan per primary vlan domain. See this 6500 configuration doc as an example -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/pvlans.html#wp1144524
I've just moved house so haven't set lab back up yet so can't test.
Jon
Hello Sarah,
the SVI is a special case and hasn't got a physical interface
according to my old book the following is enough:
vlan 40
private-vlan isolated
vlan 50
private-vlan community
vlan 200
private-vlan primary
private-vlan association 40,50
interface vlan 200
ip address 192.168.199.1 255.255.255.0
this is taken from BCMSN second edition
David Hucaby
Copyright © 2004 Cisco Systems, Inc.
ISBN: 1-58720-077-5
I used first and second edition of this book and I've found them accurate.
I think there is at least a third edition on cisco press
the current edition is 4th:
* By Richard Froom, Balaji Sivasubramanian, Erum Frahim.
* Published by Cisco Press.
* Series: Self-Study Guide.
Save to My Wish ListSave to My Wish List
ISBN-10: 1-58705-273-3
but the authors have changed
Hope to help
Giuseppe
Hello Sarah,
yes you can map multiple different secondary vlans of type isolated to the same primary vlan.
I remember the examples in BCMSN second edition about this.
I did some basic testing on private vlans and I don't remember this kind of limitation.
private vlans have been thought to limit connectivity within a single ip subnet:
instead of using multiple /30 subnets you can place servers in a single subnet but you can make them to talk only with the default gateway.
This can be useful for providers offering server hosting services: instead of wasting precious public ip addresses (one for base subnet and one for broadcast you use 4 addresses for a /30) it is more convenient to use pvlans.
Pvlans as a mean to avoid ARP attacks, man in the middle are now less used. For this DAI, IP source guard and DHCP snooping are preferred.
Hope to help
Giuseppe
Hello Sarah,
only one switch port can be associated to a secondary vlan of type isolated but you can have multiple (different) isolated vlans mapped to the same primary vlan.
Hope to help
Giuseppe
Overall Rating: 5 (6 ratings)
Correct Answer
Giuseppe Larosa Thu, 02/05/2009 - 06:25
  • Hall of Fame,
    Founding Member
Hello Sarah,
Hope to help
Giuseppe
sarahr202 Fri, 02/06/2009 - 15:27
Thanks a lot Giuseppe!
Based on your reply, the book is wrong which says only one isolated vlan(secondary) can be mapped to primary vlan.
I just want to confirm if u nderstand you right.
We can map multiple isolated vlans to same primary vlan. Am i correct Giuseppe?
thanks a lot!
Correct Answer
Giuseppe Larosa Sat, 02/07/2009 - 00:22
  • Hall of Fame,
    Founding Member
Hello Sarah,
Hope to help
Giuseppe
sarahr202 Sun, 02/08/2009 - 14:10
Thanks a lot Giuesppe!
Just one more question if You please don,t mind.
I understand the role of promiscuous port.
That is the kind of port on layer 2 switch that connects to gateway.
Let take different scenario. we have a multilayer switch with one vlan 2.
svi for vlan 2 is 2.2.2.1/24. will this svi be configured as promiscuous port? or only layer 2 port connected to gateway is configured as promiscuous port?
P.s I am using a cisco book which I no longer trust, the case in point is book says only one isolated secondary vlan can be mapped to primary vlan. Numerous times i quoted from the book only to find the book was wrong. The end result is whatever the book says ,i have to either verify it by net pro or by searching on google. Do you recommend any good book ? It will save me a lot time and save you guys from my questions as well.
Correct Answer
Giuseppe Larosa Mon, 02/09/2009 - 00:25
  • Hall of Fame,
    Founding Member
Hello Sarah,
vlan 40
vlan 50
vlan 200
interface vlan 200
David Hucaby
ISBN: 1-58720-077-5
Hope to help
Giuseppe
sarahr202 Mon, 02/09/2009 - 12:30
Thanks a lot Giuseppe! I am taking my switching exam on tuesday 10 feb .
I really appreciate your help in my preparation for the exam.
Correct Answer
Jon Marshall Mon, 02/09/2009 - 12:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
Jon
Correct Answer
Giuseppe Larosa Mon, 02/09/2009 - 13:33
  • Hall of Fame,
    Founding Member
Hello Jon,
Giuseppe
sarahr202 Mon, 02/09/2009 - 14:36
sarahr202 Mon, 02/09/2009 - 14:34
Thanks a lot Jon for your kind words and correction.
