show ASA performance command?
Feb 4th, 2009
I am going to test the ASA performance to see how much heavy load it can handle especially for vpn traffic.
The only command I knew are
show cpu
show memory
Is any other command I can use to check the performance?
Also, what's the recommend threshold for these parameters or what's the normal load - %
For example,
What's the acceptable average cpu load? 30%, 50% or even higer?
Many thanks
rico_hao40 Wed, 02/04/2009 - 13:55
Thanks.
last time i had bad experience using ASDM it cause my asa reboot, not sure why probably lower version?? Also I think running ASDM will impact the asa performance as well, so I prefer use command first… But I will try ASDM too …
BTW, what's the acceptable cpu and memory load for asa?
