sntp_main: Spurios NTP Packet rejected on socket 0
Answered Question
Feb 4th, 2009
Hi Guys,
Does anyone here have an idea what does it mean? I am using Wireless LAN controller.
Thanks in advance.
Cheers!
Correct Answer by jeff.kish about 8 years 5 months ago
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn421120.html
This appears to be a known bug that has no workaround :/ You should consider upgrading your code if you think it's causing problems. If you do upgrade, be sure to upgrade to 5.1 or 5.2, since 5.0 code isn't up to par.
Overall Rating: 5 (1 ratings)
