02-04-2009 08:22 PM - edited 03-13-2019 06:03 PM
Hello everyone
I met a problem when I integrated XMedius fax with NEC Univerge 2000 IPS thru t1 qsig.When I call the fax number, calls cut immediately
or busy signal. calls between analog and IP is ok.
NEC PABX 2000->t1->Cisco2851->XMedius fax(v5.5)/CM5
LHK2851#
043817: *Feb 5 11:21:25.203 PCTime: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x6901
Sending Complete
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
Exclusive, Channel 5
Facility i = 0x9FAA06800100820100A11C02010006052B0C090000801000000000000000000000000000000000
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0x80, '799'
Plan:Unknown, Type:Unknown
Shift to Codeset 4
Codeset 4 IE 0x31 i = 0x00
Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
043818: *Feb 5 11:21:25.203 PCTime: ISDN Se0/2/0:23 **ERROR**: isdn_init_fac_data: No Opval 0
043819: *Feb 5 11:21:25.207 PCTime: ISDN Se0/2/0:23 **ERROR**: isdn_init_fac_data: No Opval 0
043820: *Feb 5 11:21:25.215 PCTime: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xE901
043821: *Feb 5 11:21:26.007 PCTime: %ISDN-6-CONNECT: Interface Serial0/2/0:4 is now connected to N/A N/A
043822: *Feb 5 11:21:26.011 PCTime: ISDN Se0/2/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xE901
Connected Number i = 0x80, '799'
043823: *Feb 5 11:21:26.079 PCTime: ISDN Se0/2/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x6901
043824: *Feb 5 11:21:31.119 PCTime: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x6901
Cause i = 0x8190 - Normal call clearing
043825: *Feb 5 11:21:31.119 PCTime: %ISDN-6-CONNECT: Interface Serial0/2/0:4 is now connected to N/A N/A
043826: *Feb 5 11:21:31.119 PCTime: %ISDN-6-DISCONNECT: Interface Serial0/2/0:4 disconnected from unknown , call lasted 5 seconds
043827: *Feb 5 11:21:31.119 PCTime: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0xE901
043828: *Feb 5 11:21:31.203 PCTime: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x6901
Cause i = 0x819F - Normal, unspecified
LHK2851#
LHK2851#sh runn
voice call disc-pi-off
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 2 hs-redundancy 2 fallback cisco
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
h225 timeout tcp establish 3
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extensions operation-value-tag local
isdn bchan-number-order ascending round-robin
isdn outgoing ie facility
isdn outgoing ie display
no fair-queue
no cdp enable
voice-port 0/2/0:23
cptone HK
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 101 voip
destination-pattern 79[1,3,5,7,9]
voice-class h323 1
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
codec g711ulaw
fax-relay sg3-to-g3
fax rate 14400
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
Thanks in advance.
02-12-2009 09:39 PM
anyone meet the familiar things? please help.
Thanks a lot.
