4 digit to Call Manager
Answered Question
Feb 4th, 2009
Hello,In a nutshell,the welcome message prompts the caller to press # and than the 4 digit employee extension to call directly a CUCM user,so this is no limited to agent. Any idea , i tried the get digit step and call redirect to a CTI but is not working. Any idea?!?!??! Thanks in advance.
Correct Answer by Jonathan Schulenberg about 8 years 1 month ago
Easy enough:
Start
Accept
Label: GET_EXTENSION
Get Digit String [Prompt:"Please enter the four-digit extension of the user you want to dial."]
--Success
--If (strExtension.length(4))
----True
------Call Redirect (strExtension)
--------Success
----------Set Contact Info: Handled
----------GoTo: END
--------Busy/Unsuccessful
----------Play Prompt: ("That extension is not valid. Please try again.")
----------GoTo: GET_EXTENSION
----False
----Play Prompt ("Extensions must be four digits.")
----GoTo GET_EXTENSION
--Failure
----Play Prompt: ("Are you still there? Please enter a four-digit extension of the party you wish to speak with.")
Terminate
End
The CTI Ports will need to have a CSS that includes whatever partition(s) the directory numbers [extensions] exist in.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Thu, 02/05/2009 - 06:36
  • Cisco Designated VIP,
    2017 IP Telephony
Easy enough:
Start
Accept
--Success
----True
--------Success
----------GoTo: END
----False
--Failure
Terminate
End
Marco Villani Thu, 02/05/2009 - 20:09
I can't make it to work,if i dial the CTI number unity answer and when i dial the 4 digit i get the default sytem voice, we are having some issue. I'm attaching the script, if somebody can tell me what i'm doing wrong really appreciate ,Thanks.
Marco Villani Sun, 02/15/2009 - 22:14
Thank you j.schulenberg ,after reading your reply I was confusing CTI Ports and CTI Route Points.after paying more attention at your post i realized my mistake and checked the CTI Ports. my CTI had a diferent CSS than the phone, Once i change the CSS in the CTI Ports my original script worked. what i did I simply use a call riderect and setup a string with 4 as a value.
