Traffic Consideration when deploying WLC
Feb 5th, 2009
Hi There, can any body tell me what is the traffic generated by controllers & AP to communicate with WLC. If WLC is across the WAN...what are the traffic consideration one should take care..
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 02/05/2009 - 06:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Scott,
Good find my friend! +5 points for your ongoing great help here!
Cheers!
Rob
jain.nitin Thu, 02/05/2009 - 12:10
HI it was really helpfull thanks but my concern is to find the bandwidth used by communication between WLC & WCS. My WCS is across the WAN & all the controllers from the branches would be joining WCS which is in Data Center across WAN..so need to have some kind of overview wht would be the bandwidth used by these communication
Scott Fella Thu, 02/05/2009 - 14:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
WCS uses snmp so it would be the same as if you had a network monitoring tool.
Trending Topics - Security & Network
