What do IPSEC mean under Security -> AAA -> Radius -> Authentication
Feb 5th, 2009
I can't find exact information regarding the IPSec checkbox in Security -> AAA -> Radius -> Authentication.
On the Cisco Wireless LAN Controller Configuration Guide 5.1, it says "Check the IPSec check box to enable the IP security mechanism, or uncheck it to disable this feature.
The default value is unchecked."
What is exactly mean by IP security mechanism?
Does this mean that I can terminate VPN client over my WLC?
Take note that this options appeared even though no crypto card installed in my controller.
Stephen Rodriguez Thu, 02/05/2009 - 07:36
This is old code from the Airespace days. There used to be a VPN module that would ride in the WLC. No longer supported, well can't buy it new, but if you had one already...you get the idea.
HTH,
Steve
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
