Does the ASA support OpenVPN
Feb 5th, 2009
I've been looking at the OpenVPN software.
I have the OpenVPN software configured as a client and would like to use the ASA as the VPN server for this software.
It is an SSL software and as such I've tried configuring the ASA to terminate such connections but to no avail.
Has anyone set this type of scenario up before, or know if it is even supported?
dbowley Thu, 02/05/2009 - 06:25
Yes.
Everything is setup on the ASA so that it would work if using a standard SSL connection to the ASA.
I'm just looking for more of a clarification as to whether any knows if the OpenVPN software works or is at least supported.
