Third-party SIP Phone with CCME
Feb 5th, 2009
Hi all
have some body configure 3rd-party sip ip phone with ccme 4.1 or later.there is no documentation available on net for such scenario.or give me idea how it can b implemented.
Tahir
Nicholas Matthews Thu, 02/05/2009 - 05:29
  • Red, 2250 points or more
Hi Tahir,
This is what the minimum configuration looks like:
voice service voip
sip
registrar server
voice register global
mode cme
source-address 1.1.1.1 port 5060
max-dn X
max-pool X
voice register dn 1
number 1000
voice register pool 1
id mac XXXX.XXXX.XXXX
type ! If it's 3rd party, omit this
number 1 dn 1
username X password X ! Required if IP phone's address is on different subnet than SIP CME source address
You can also look at the documentation here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1025405
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1073239
hth,
nick
tahirjamil Sun, 02/08/2009 - 11:34
Hi Nick
Thank you for response,I tried this configuration with x-lite softphone I m getting authentication problem i attached my config with debuging on kindly check it and suggest what i can do
Nicholas Matthews Sun, 02/08/2009 - 12:51
You need to make sure the x-lite client is actually adding an Authentication Header to the REGISTER message it sends. This looks like it would be an endpoint configuration issue.
You should see something like this:
-> REGISTER ( no authentication)
M- 401 Unauthorized
-> REGISTER (authentication)
<- 200 OK
You can try taking the 'authenticate register' message out of your voice register global configuration as well.
There also is not a DN defined on the phone. You probably want to add 'number 1 dn 1' to your voice register pool configuration.
hth,
nick
