Voip monitoring
Feb 5th, 2009
Dear all
I have cisco VG with E1 pri lines.
i want to monitor everything about my calls.
I used cdr on my router using cisco acs but this gives me just on .csv files.
I need something that reports graphically.
do you know any software or solution?
Nicholas Matthews Thu, 02/05/2009 - 05:31
If you use MGCP with CUCM, Real Time Monitoring Tool will be able to give you a lot of these statistics.
Otherwise - you can configure AAA voip accounting, and have a 3rd party system do all of the analysis. I think Stonewall (?) is one program that does this.
hth,
nick
miskoolak Thu, 02/05/2009 - 07:31
Dear nick
right now I am using Cisco ACS but the information are not suitable..its in .csv format.
