Ayodeji Okanlawon Thu, 02/05/2009 - 06:02
  • Cisco Designated VIP,
    2017 IP Telephony
If you dont want a particular phone to have access to the personal directory or corporate directory, then what you can do is to enter a fake ip address on the directory url for that phone.
Simply scroll down to the url settings on the phone and enter an adress on the corporate directory eg http://youarenot allowed.
webstd.design Thu, 02/05/2009 - 06:14
But now here is text screen - Host not found.
How I can hide this text without changing any phone's firmware?
Ayodeji Okanlawon Thu, 02/05/2009 - 06:28
    2017 IP Telephony
Thats the whole idea...It shouldnt find the host. There is no way to hide the text
webstd.design Thu, 02/05/2009 - 06:27
Maybe there is some fake adress that I can use here?
I mean I want to Phone work without any string
error but more quickly and without Personal Directory
Ayodeji Okanlawon Thu, 02/05/2009 - 06:29
    2017 IP Telephony
you can enter a fake ip address there
webstd.design Thu, 02/05/2009 - 07:28
I have done somechanges with ip http://CUCMIP:8080/ccmcip/xmldirectory.jsp XML file that phone requests from CUCM.
<?xml version="1.0" ?>
Select a directory
Personal Directory
http://xxxxxxxxx:8080/ccmpd/pdCheckLogin.do?name=undefined
Corporate Directory
http://xxxxxxxxx:8080/ccmcip/xmldirectoryinput.jsp
Now it's look like this
<?xml version="1.0"?>
Select
With this feature I hide not needed fields.
Ayodeji Okanlawon Thu, 02/05/2009 - 07:41
    2017 IP Telephony
What you have done applies to all phones. I thought what you wanted was for some phones...
Well done! Good one.
webstd.design Fri, 02/06/2009 - 04:51
I wonder, that there isn't any standart rule fot disabling Personal Directory in CUCM for some users
Yes, that makes sense removing the reference in the XML file; but where do you upload the file to
after the modifications? xmldirectory.jsp is not in the TFTP directory. Actually it should be in the HTTP directory??
If you could tell me where/how to upload this file to on CUCM6/CUCM7 after modifying it, I'd greatly appreciate it.
Yup, I also am trying to eliminate Personal Directory from showing up on ALL IP phones.
THANKS!!
Justus_Pradana Mon, 02/09/2009 - 21:10
do you want to disable it in a single phone or in all phones registered to the CM?
if in single phone you can delete the url in ip phone,
but if you want to disable it in all phones,delete the url in personal directory url in enterprise parameters.
regards
