Presence LDAP Search context
Feb 5th, 2009
Can Presence 6.0 look inside of groups for its search? In testing, I was able to pull users from the Users container, but when I changed my context string to pull from a group, it did not work.
So, is it possible or do I have the incorrect context?
Below are the strings I used (both returned no results):
&(objectcategory=person)(memberof=Presence Users,OU=Company Groups,DC=blah,DC=blah,DC=net))
CN=Presence Users,OU=Company Groups,DC=blah,DC=blah,DC=net
mackersaffiniti Thu, 02/05/2009 - 08:14
I have all our users in a group for IPT and then have have the following LDAP filter applied to search only that group and it works great.
(&(objectCategory=user)(memberOf=CN=IT-CS-Voice-IPPHONE-EU,OU=Groups,OU=VOICE,OU=CS,OU=IT,DC=XXX,XX=ds,DC=XXXXX,DC=XXXX))
cplatt01 Fri, 02/06/2009 - 06:33
What version of Presence are you currently running? I am on 6.0(3).
Johann Aicher Mon, 02/09/2009 - 08:15
Hi thats sounds great!
Is this config supported from Cisco ? And where is the corresponding Docu ?
Can we use that also on CUCM for LDAP import?
Reg.
Johann
mackersaffiniti Mon, 02/09/2009 - 23:45
Hi Johann,
Yes works fine in CUCM, and no complaints from Cisco.
I did have it running on presence on 6.0(4) but that system is not running now.
Best regards,
Mackers
cplatt01 Tue, 02/10/2009 - 05:05
So you are able to pull users from groups in both CUCM and Presence? If possible could you share your syntax? From Presence I can only pull users from containers and not recursively from groups.
Thanks!
