02-05-2009 05:16 AM - edited 03-11-2019 07:46 AM
HJi,
<br />I've a Cisco ASA with software 8.0(3).
<br />I've PC behind ASA (say for example 254 hosts on interface inside); I want to do global nat on interface outside with two adddresses (say for example 100.100.100.100 and 100.100.100.101).
<br />The instructions that I have used are:
<br />nat (inside) 1 10.0.0.0 255.255.255.0
<br />global (outside)1 100.100.100.100-100.100.100.101
<br />
<br />I want that the first PC is global natted (patted) with 100.100.100.100, the second with 100.100.100.101, the third with 100.100.100.100...but the instructions above are not working...in other words i want that the ip of inside interface are alternately natted with the two addresses, and that all host simultaneously are natted on outside interface.
<br />Has anybody an idea?
<br />
<br />Thank you.
<br />Best regards,
<br />Massimiliano.
<br />
02-05-2009 05:32 AM
If you want to enable internet only for 2 ip address u can use the following commands
natnat (inside) 1 100.100.100.100 255.255.255.255
nat (inside) 1 100.100.100.101 255.255.255.255
global (outside) 1 interface
global (outside) 1 XX.XXX.XXX.XX ( Ip address)
subsequently you can keep adding the host those who wants to access internet.
Rama
02-05-2009 05:55 AM
better you check the link below
https://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml
hope it helps
