Regular Expressions
Feb 5th, 2009
Does anyone know if there is any material out there that has pre build regular expressions? I can't seem to figure these things out. I'm wanting to block P2P traffic on our network but the ASA only can block Gator and Kazaa by default.
cowetacoit Thu, 02/05/2009 - 07:35
I've built a class map/policy map with this Doc but i still can't figure out how to build my own REGEX for p2p such as Gnutella, Bittorrent, morpheus....etc. Does anyone have some documentation on the REGEXs?
Jithesh K Joy Thu, 02/05/2009 - 20:22
Please visit the following url :
Could you please try the following conf to block the p2p protocols
http-map inbound_http
port-misuse p2p action drop log
port-misuse tunneling action drop log
class-map http-port
match port tcp eq www
policy-map global_policy
class http-port
inspect http inbound_http
service-policy global_policy global
cowetacoit Fri, 02/06/2009 - 05:35
the HTTP-MAP command isn't supported on the newer asa. :/ NBAR seems to be the best solution for what i am looking for but i'm not sure i want to run it on my Edge router connecting to my ISP. We have an ASA5520 > Cisco 2811 > ISP. Seems like the ASA would have a similar feature like NBAR with PDLMs.
