ASDM issue with ASA on management interface
Feb 5th, 2009
I am trying to access the ASDM of ASA management interface via https. The certificate pops-up but after accepting it, it says 'Internet Explorer cannot display the webpage'.
I am able to ping the management interface and port 443 is open.
I am however, able to https into the inside interface of the ASA. Is there some specific configuration to access management interface via https. The http is allowed from the source host on the management interface.
cdusio Sat, 02/07/2009 - 05:04
Are you trying to access it from the management subnet directly or are you trying to access the management interface form the inside? Sounds like it should be fine if you are on the management subnet.
