CSM - Load balance using Server CPU
Feb 5th, 2009
I have a customer who requires the load-balancing prediction
algorithm to be based on the CPU level of the Server. So the server with the least CPU is chosen at the laod-balancing stage.
Is there a way to do this?
Thanks James
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Thu, 02/05/2009 - 18:48
Hi James
With CSM the only option is DFP (Dynamic feed back protocol). If your application vendor provides DFP agents (which is very unlikely) for the application then these agents can be installed on App servers for the desired purpose.
Config details at
With ACE you can use SNMP based probes to achieve what you are looking for.
Syed Iftekhar Ahmed
james_46 Sat, 02/07/2009 - 06:50
Hi Syed
Thanks for getting back.
Perhaps i am getting mixed up between CSM and ACE.The module purchased is a ACE20-MOD-K9= for a 6500 chassis
Can the SNMP based probes be used with this module?
Syed Iftekhar Ahmed Sat, 02/07/2009 - 11:40
Yes, with ACE its possible.
The Load balancing algorithm "Least-loaded" will help you to loadbalance on the basis of CPU load.
You need to know the snmp OID for CPU load on the server. ACE will send
periodic SNMP probes to retrieve that value and use it in the load
balancing decision.
You can use total of eight such OIDs like CPU load, available memory or disk space.
james_46 Mon, 02/09/2009 - 06:19
Thanks Guys
I was of course going to give Syed five stars but Gilles just beat me to it there ;o)
