upgrade ccm 3.3 to 6.1(2)
Feb 5th, 2009
What is the best process for upgrading 3.3 to 6.1?
We have new servers for 6.1 and they have been licensed by Cisco.
I am not sure how to move the config, phones, jtapi, etc...all the stuff over to 6.1? I also do not know Linux system?
Thanks.
Jaime Valencia Thu, 02/05/2009 - 08:42
  • Cisco Employee,
  • Hall of Fame,
    2011
there is no direct upgrade to 6.1(2) from your version, 4.1(3) is the minimum to use DMA and get the info automatically
if you need to do it directly you'll have to export all the info with BAT and then reformat and reinsert into 6.1(2) with BAT as well
java
if this helps, please rate
dakshash_shah Thu, 02/05/2009 - 08:45
Hello Java,
Thank you for your reply.
I knew there was not direct upgrade, that is why we got new servers.
Where can I find info on how to use BAT and what info to collect to export into 6.1(2)?
How do I access the GUI once the MCS server is up on the 6.1(2)?
what do you mean by reformat?
Thank you.
Doc
Jaime Valencia Thu, 02/05/2009 - 08:51
  • Cisco Employee,
  • Hall of Fame,
    2011
BAT info is available on CCO, you'll have to export all details
simply http://server_IP from another PC, NOT FROM THE SERVER
BAT formats are not the same between versions, it's not as simple as taking a file and using it in another version. you'll have to adjust the info to the format needed for the new version
even if your servers supported the version still there's not upgrade. read the upgrade instructions to understand how this goes because fresh or upgrade you need to blow out all the previous info independently it's a new/old server. it's not as running a .exe and got the new version just like that
java
