show spanning vlan 50. It shows an interface named "st5" which is blocked.
Feb 5th, 2009
The line is:
<br />St5 Back BLK 100 128.876 P2p
<br />
<br />What is this st5 interface? I can guess that it's about stack5. However what does it mean exactly?
<br />
<br />I am using a stack of 5 Cisco 3750 switches.
<br />
<br />Thanks!
<br />Difan
Overall Rating: 4 (1 ratings)
Yudong Wu Thu, 02/05/2009 - 12:27
Yes, it's stack port but I am not sure how it is numbered.
To my knowledge, it should not be displayed in "show spanning" unless debug spanning is enabled.
If not and your switch running a old code, it might be a bug.
Difan Zhao Mon, 02/09/2009 - 15:07
The second link helps! The first link is too long... I will read it some day... Thanks!
