effectively breaking EIGRP / BGP redistribution count-to-infinity loops
Feb 5th, 2009
My environment is a 2 router and 2 Multihomed MPLS providers running EIGRP and BGP with redistribution. When I have failovers between MPLS providers I run into random infinity loops. Is there a way where I could establish the 2 BGP AS numbers to be shared. I think that would help the looping issues with redistribution.
Giuseppe Larosa Thu, 02/05/2009 - 11:18
Hello Scott,
if you have multiple points of mutual redistribution you need to implement routing policies.
A useful tool are route-tags you can mark with a route-tag routes injected into EIGRP from BGP.
route-map BGP-to-eigrp deny 10
match route-tag 5000
route-map BGP-to-EIGRP permit 20
set route-tag 1000
the route-map for EIGRP to BGP will do the opposite
route-map eigrp-to-BGP deny 10
match route-tag 1000
route-map eigrp-to-BGP permit 20
set route-tag 5000
do this on both CE routers using consistent route-tag mappings
router eigrp 1000
red bgp 1000 route-map BGP-to-eigrp
default-metric 10000 1000 1 1 1500
This protects the network during transitions.
Hope to help
Giuseppe
