Unable to Launch Executables for Non-Admin Users with Cisco NAC Stub Agent
Feb 5th, 2009
I'm getting error "It is not a qualified file to be executed" when I try to launch a executable program through the CCAAgent Stub for a non-admin user.
I have created certificated, signed and all those procedures are done. Still getting the same error.
What might be the issue?
aghaznavi Wed, 02/11/2009 - 08:14
CCAAgentStubTool.exe's certificate expired. This is likely the cause of problem. This only affects non-admin user. Since this is so far only reported from Vista user, it might only affect Vista user, meaning the Windows API we use to check the validation of the cert might have slightly different behavior on XP in terms of expired cert.
sampathsundararajan Wed, 02/11/2009 - 08:16
Thanks for the response. But, the certificate for that executable is not expired. It's there till 2010.
Can there be any issues with registry entries?
