02-05-2009 11:26 AM - edited 03-17-2019 09:38 PM
I have a question about some voip/vpn configuration. I've got two sites that have 1760 routers with fxo/fxs cards that are going to be tieing the two phone systems together with a couple of voip trunks. These are secondary devices on the network, but addressed with a 2nd wan ip. The only traffic going through these routers is voice/voip.
My question is about this voip setup with vpn. If I configure an easy vpn server on the router at site 1 and easy vpn client on the router at site 2, and have a site-to-site vpn connection, will the voip traffic pass over that? Is there a need to have a vpn? Any benefits to sending the voip data across vpn, other than the obvious encryption of the "call"?
Here's my voip configuration as it sits on the bench in testing:
SITE 1:
version 12.4
hostname SITE 1
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
interface FastEthernet0/0
ip address 192.168.254.30 255.255.255.0
speed auto
no shutdown
no ip http server
no ip http secure-server
control-plane
voice-port 2/0
connection plar opx 290
voice-port 2/1
connection plar opx 291
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 190
voice-port 3/1
connection plar 191
voice-port 3/2
voice-port 3/3
dial-peer voice 180 pots
destination-pattern 180
port 2/0
dial-peer voice 181 pots
destination-pattern 181
port 2/1
dial-peer voice 190 voip
destination-pattern 19
session target ipv4:192.168.254.40
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
transport input telnet
end
AND SITE 2:
version 12.4
hostname SITE 2
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
ip address 192.168.254.40 255.255.255.0
speed auto
no ip http server
control-plane
voice-port 2/0
connection plar opx 280
voice-port 2/1
connection plar opx 281
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 180
voice-port 3/1
connection plar 181
voice-port 3/2
voice-port 3/3
dial-peer voice 190 pots
destination-pattern 190
port 2/0
dial-peer voice 191 pots
destination-pattern 191
port 2/1
dial-peer voice 180 voip
session target ipv4:192.168.254.30
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
end
02-05-2009 04:10 PM
Hi, not sure why you posted in video since it is a voip question, anyway to answer your question, is not that you have to use vpn all the time just because is crypted, if the routers are facing the internet they can do perfectly do without. That is the simplest and easier to diagnose configuration, with also the less overhead.
Eventually, again if yo don't care about encryption, you can setup a GRE tunnel to connect any subnet behing the routers. Again voip can normally work outside the tunnel as it is router-to-router communication after all.
In any case make sure you configure an ACL blocking H.323 and SIP coming from unknown addresses, because if you have a PSTN connection, it has become a common fraud with people making expensive calls.
