ASR1002 SFP modules
Feb 5th, 2009
Is the GLC-LH-SM SFP compatible with the ASR1002 and how does it differ from the SFP-GE-L adapter?
Leo Laohoo Thu, 02/05/2009 - 13:44
GLC-LH-SM SFP 1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength.
SFP-GE-L is 1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength, extended operating temperature range and DOM support.
Unfortunately, GLC-LH-SM will not work for the Shared Port Adaptor. Depending on your SPA, you need to choose what SFP-GE models you need. Please refer to Cisco ASR 1000 Series Shared Port Adapter Support (')">, choose your SPA port density you require and then you'll find out what Optical Modules you may use.
I have no idea how accurate these documents are because we have two ASR1002 and the SPA's are fully populated with GLC-TX (or what could be GLC-TX) ... and they work!
mrqjohnson1 Thu, 02/05/2009 - 13:52
Thanks Leolaohoo,
I am wondering if there is any difference other than the Extended Operating temperature range and the optical monitoring. I cant find any documentation anywhere that shows the GLC-LH-SM SFP being compatible with the ASR1000 SPA. I can find where the SFP-GE-L is compatible with the SPA for the ASR1000. Can you point me into the direction of documentation that would help me out?
Leo Laohoo Thu, 02/05/2009 - 13:57
Afraid not. There are three ways to get around this.
1. Contact your Cisco reseller or a Cisco sales engineer (which specialize on the ASR1000) and ask the question.
2. If you have a few of the spare GLC's lying around, it's worthwhile plugging them into the ASR's and see if they are detected.
3. Or you can go to ASK THE EXPERT - ASR1000 SERIES ROUTERS
Like I mentioned in my previous post, we have two ASR1002's and it's fully populated with GLC-TX and work.
Hope this helps.
eduardo.ramirez Tue, 11/01/2011 - 18:09
Hi Guys I have couple ASR 1002 running with GLC-LH-SM= with no problem, also I spend some time looking for the correct answer even I opened a TAC but nothing....
So I think the only difference is Extended Operating temperature range and the optical monitoring and obviously price!!!
