single ap and multiple ssids
Answered Question
Feb 5th, 2009
  • Bronze, 100 points or more
Hi Every body!
Is it possible for sinle "AP" to have ultiple ssids, If yes, then it must effect the performance as " ap" has to send beacon for each ssid then switch the traffic from each ssid.
Could anyone explain me this please?
thanks a lot!
Correct Answer by jeff.kish about 8 years 1 month ago
Yes, Cisco APs can now support up to 16 SSIDs. And you're correct that it must beacon for each one, so you should be smart about how many you use. Simply use the minimum of what you need!
Overall Rating: 5 (1 ratings)
Correct Answer
jeff.kish Thu, 02/05/2009 - 15:01
  • Silver, 250 points or more
