Communication with AD
Feb 5th, 2009
On CCM, 4.x, 5.x, 6.x and 7.x the communication between CCM and AD is safety or clear text?
If clear text, I think it, is possible to put safety in communication?
Jaime Valencia Thu, 02/05/2009 - 13:28
AFAIK we still do clear text as with windows version and is non-configurable
if this helps, please rate
gogasca Thu, 02/05/2009 - 14:53
Frederick is correct 5.x we enable under Directory settings, and we still need to install certificates.
In 4.x you need to run the plugin and enable LDAP over SSL.
You use a SSL certificate on the publisher for the connection between ccm and ad to secure connection.
If you are faimiliar with certificates its pretty easy.
Frederick Nielsen Thu, 02/05/2009 - 13:51
For CCM 5.x and up, you can enable LDAPS (LDAP over SSL) which uses encrypted communication between the publisher and the AD LDAP instance.
