unity connection 2.1 security configuration failed
Answered Question
Feb 5th, 2009
Install of unity connection 2.1 from CD is good until it gets to the end. I get a "security configuration failed" error. The security password is a strong password. The security password is used "to authenticate between clusters", however, I am only using one unit connection server. Any help with this appreciated
Correct Answer by Bradford Magnani about 8 years 3 weeks ago
Awesome! :)
I would attempt the install again, yes.
Overall Rating: 5 (2 ratings)
cbriones1 Thu, 02/05/2009 - 12:39
This was an old post, wanted to know if anyone had/ having the same issues.
cbriones1 Thu, 02/05/2009 - 12:42
Bradford Magnani Thu, 02/05/2009 - 12:44
Chris,
I saw an issue in the past where the password was "too complex" and a more simple one was re-entered. This ended up resolving the issue. Give that a shot.
Brad
cbriones1 Thu, 02/05/2009 - 13:16
Thanks for the fast reply, i tried a couple more simple PW and it's not taking. It runs the Security Configuration and comes back with the same error. I'm not sure if this might be a part of the problem, but when it completed the install and i was getting the error i noticed the DVD ejected itself. should i pop the DVD back in and try again?
cbriones1 Fri, 02/06/2009 - 15:07
Brad, i reinstalled and put in a password not to complex and it took.
Mahalo!
